proppastie
New member
I am attempting to convert the Carbon Dragon Ultra-lite Sailplane to aluminum structure. There is a spec. in Basic Glider Criteria (FAA) for a 150# limit load at the tip. Depending on the assumptions made with the wing structure the axial loads on the rear spar are from 3000# to 1500#. The latter is calculating a Phantom beam at the Leading edge, and the former is for no inclusion of the Leading edge in the calculation. How do experienced aircraft designers stress a D box leading edge structure,... fabric aft of the rear spar. Do you position a phantom beam at the centroid or some other place for the calculation of the stress????
