Wipeout frame size
Whiskeytown
Using the Express Tools -TEXT-TEXT MASK command, the wipeout makes a rectangle just big enough for the masked text. I would like a larger mask in order that the text has a little whitespace, devoid of drawing features, around it. Is there a way to change settings for the frame properties?
Hi Jack Daniels [wink],
use the option OFFSET inside the TEXTMASK command. This variable is relative to the textsize.
best regards, Lothar
ADT 2004
ACAD 2002
