I have a water system application in which control for several reservoirs is centralized in the master station and comms are via voice grade phone lines. I'm considering a distributed system upgrade in which a large programmable RTU or PLC will perform the control for each site (reservoir and associated wells) with spread spectrum radio modems communicating with a micro RTU or PLC at each component site. I've seen several small microPLCs with integrated radio modems but none from companies I'm familiar with. Has anyone had experience (good or bad) with such a device and what would you recommend? I'd like to stick with a common SCADA protocol (modbus, DNP, etc.).
Thanks.
Thanks.
