Hello All,
I am trying to find the rate at which water will be withdrawn from a waterbody with "a vac truck". I know that the hose will be screened to prevent fish capture and that the hose will be 3" in diameter or less.
I expect that there are many different types of vacuum trucks in existence, making this a difficult question to answer.
The value does not need to be highly accurate (and if there is a range of values, knowing the upper bound would be suitable).
Does anyone know of a source I can turn to for this? Perhaps a guideline which recommends a maximum withdrawal rate using a vac truck?
If it makes a difference, the withdrawal will occur in northern Alberta.
Thanks!
Dave
Thanks!
Dave
