  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Wondering if this swept profile is possible
Siress
Industrial
Jan 11, 2006
20
0
0
This is the type of check valve found in veins. I would like to know of a way to model these valves quickly. My intuition was that I could revolve sweep the profile with a constraint on the inner diameter of the tube. This doesn't appear to work (although it showed a preview of such while I was playing around with the settings...go figure.)
Any help would be appreciated!
-Siress
Chris,
Glad you enjoyed my model your surfaces look good. Try to see if you can do a Surface-Surface Loft using the two surfaces to get a solid instead of knitting and using thicken with Make Solid Body.
I see you have Real View enabled. I'm currently using an unsupported card but I do my own tech support. I've always hated the classification of Gaming/CAD Graphics Cards. You'd think 1 card could do both but then the Card Companies wouldn't make as much money.
[cyclops]
Michael
