structurebeton
I am designing a 3 story residential house, with a combination of steel columns, steel beams to support floors, with a combination of wood bearing walls and other wood wall components.
Is there any issues I should be concerned, such as when I will specify 40 ft tall single columns...which will need lateral bracing at each floor level...any suggestions on how to do that with wood elements?
Should shrinkage differential between the two materials be a concern?
Any comments appreciated. Thanks.
