I am working with an existing condition. We have an existing steel beam (I think size W12x16) bearing on an existing CMU block bearing wall.
Due to a new framing layout, we will need to install a column directly above where the existing steel beam at the bearing location. The beam doesn't have a stiffener plate at bearing. Can we jamb wood blocking between the flanges in lieu of adding a stiffener plate? Or what else could we do to avoid welding?
