ajk1
- Apr 22, 2011
- 1,791
I am reviewing a cottage that was built last year. One of the items I am concerned about is the detail at the top of the wood post. I have prepared the attached sketch of the interface of top of wood post to underside of the wood beam. The load bearing exterior stud wall has no exterior face sheathing, and sits on top of the 1st floor joists which in turn sit on a a 4-ply wood beam (4-2x12's) which in turn sit on top of a 5½ x 5½" wood post. Connections are only toe-nails. Is that how that would normally be done? It seems a bit wobbly and not particularly effective against uplift forces.
Questions:
1. Should there be a metal strap from the built-up wood beam to the post, or a metal bracket fastened to the top of the post and the beam?
2. The built-up wood beam spans about 11', and alternate plies are spliced within the spans. Does the built-up wood beam require any lateral bracing to its bottom?
Questions:
