Hello group,
In Florida I notice many situations where porches open on 3 sides have 4x4 post with 2- 2x10 in post caps on the open long side parallel to the front wall of the house.. On the beams is a porch roof diaphragm. The bottom of the post usually has a simple PB 44 base plate which appears to be pinned.
How can these post take the lateral shear from the edge of the diaphragm and also provide any support to the diaphragm?
It seems to me the top of the post is free to rotate since there are no shear walls in plane with this edge of the diaphragm.
Also if the post was embedded in concrete or in a moment resisting base is there an internal moment ( maximum ) in the post at the base AND a resisting moment (thrust) equal to the post moment ( M=PL) at the interface of the post and resisting material being either the concrete or the base plate if one is used?
And last, where does the the P=V shear occur and is it in addition to the thrust force?
Thanks,
Jeff
Thanks,
Jeff
