Spats:
Come on, give us a break, of course column length and buckling must be reviewed per the NDS, but they can’t take much lateral load without bracing or knee braces, etc.. But, the most important thing is the deck proportions and you’ve neglected to mention them. Does this deck have a 10' ledger attached to the bldg. and cantilever out from the bldg. 30'? Or, is the ledger on the bldg. 20' long and the posts and beam a 8 or 10' out from the bldg. Obviously, there is a difference btwn. these two. Tie backs, into the bldg. floor diaphragm are important, so the deck can’t just be zipped off the bldg. by a lateral load; and of course, they are dependant upon the framing direction within the bldg. to get that load back into the bldg. floor diaphragm. The IRC/Deck Design Guides have picked a conservative, and arbitrary value for these strengths. I prefer to put these connectors in a deck joist or two from the deck edge, so that the deck diaphragm can develop on either side of the connector, as opposed to being fixed to the edge deck joist. Of course, this reduces the lever arm on these connectors, that isn’t usually the issue. I have also used light cables, turnbuckles, eye bolts, from corner to corner of the deck and back into the bldg. floor diaphragm. I think the advantage of this is that it essentially puts the entire deck into compression back into the bldg. The difference is that one is prescriptive and anyone can do it without much thought, while the other is based on some engineering judgement and real engineering design. In terms of diaphragm action, the 2x6's are not appreciably superior to 5/4x6 decking, but diagonal orientation of the decking does improve the diaphragm action, and maybe it can even be kinda artsy too.
