DigiAlmond
Hey all!
I'm working on a higher end residential home, and the goal from the architect is to "use as much wood as we possibly can". I'm all on board with that. Now I'm running into an issue where a wood "girder" is supporting a beam that is approximately 10" above said girder. Both beams are approximately 16" deep. Now one solution would obviously be to move the girder down so that the beam can bear directly. This would work but it has some issues I'm trying to skirt around, but notching the beam would be such an easy solution... That got me thinking: a notched beam bearing is usually pretty big no. Notching a beam effectively reduces the depth of the beam by however deep the notch is. However in a flitch beam, couldn't the bolts start to engage that "lost" depth? I'll probably still try to find a better solution, but what do you guys think? Am I missing something?
Thanks!
Thanks!
