spats
- Aug 2, 2002
- 655
I'm designing a wood pergola on the oceanfront in Florida. It will be built using standard pressure treated SP dimension lumber, with 6x6 wood posts embedded in concrete. The "roof" will be 2x4s laid flat at 6" on center, supported by joists at 2' on center. I'm dealing with the Florida Building Code, which is basically IBC/ASCE 7-10. Question is, do I need to design the "roof" for 20 psf minimum construction live load? It's not truly a roof, and nobody is going to be stacking construction materials on top of it. Is there anything in the code that would allow less than 20 psf over the entire surface area (treating as solid)?
One of the reasons I ask is that the positive (downward) wind loads are killing me. I don't know what else to do besides treat it as an open building (ASCE7 Section 27.4.3). And then there's the fact that the "roof" surface is only about 60% solid. Would it be proper to apply the prescribed plus/minus wind loads to only the solid surface? I'm getting into 3Xs, which are not readily available in PT, and not readily available in the lengths that I need.
