Anyone know the best way to model 1/2" plywood on new single level gable roof addition to house such that it can be shown to provide adequate lateral load resistance. I have created plates between each roof rafter and meshed them (this I believe I have done correctly to transfer load from plate points to members) but do not know what property values to give the plywood under "General Material" spreadsheet.
Should it be modeled as Isotropic or Orthotropic?, E and G values? Poison ratio?
Once modeled correctly, couldn't I check the maximum in-plane force in x and y direction and compare to unit force allowable values of plywood/fastening panel by referencing the NDS diaphragm tables?
Would the model be giving reasonable results for lateral deflections?
The diaphragm is actually transferring load as a cantilever reaction against the host structure.
