canwesteng
- May 12, 2014
- 1,700
I'm doing a deck "design" for an as built deck for an acquaintance, essentially just figuring out what needs to be fixed so I can put a stamp on it to get the city to approve it. The posts sit directly on concrete (pressure treated, still a concern though for rot).
I mostly work in industrial, so rarely deal with wood, and if this came up I would just make the contractor tear it down and install a proper base, or ignore it if it was a temporary install. Probably neither are great options here though. I'm thinking jacking up the deck, and placing some poly or something between the pile and the post. Should I go the whole nine yards and jack it up and put a base plate on to get separation between the two?
The project is in a fairly dry region, but the post base would be damp for some time during spring snow melt.
