jdgengineer
- Dec 1, 2011
- 754
We have a condition where we have wood framing built on top of a concrete topped composite metal deck (2.5" topping over w2 deck). We have conditions where we have 6x6 posts within 2x studwalls that sit on top of the metal deck. We have steel beams located directly below the posts and below the deck but the load has to transfer through the wood sill plate to the concrete topped metal deck to the steel beam below. The posts are not especially highly loaded.
How have you evaluated the capacity of the deck to transfer the load? We have conditions where the deck may be parallel or perpendicular. I know that deck manufacturers give web crippling data for loading through an untopped deck, but not sure how to evaluate a concrete topped deck for the load transfer.
Worst case we could cut out the deck at the post locations so we have solid concrete support below the posts to the steel beams but want to avoid this where possible.
Thoughts?
Thoughts?
