Lumber (usually of KD Lodgepole Pine and Spruce) is often used to make a protective wrap on large pipelines, to protect damage to the anti-corrosion coatings caused by rugged terrain, rock, etc.. during the lowering in and burial. This has been a common sense solution over the years. Now, in regions unfamiliar with this proven solution, Pipeline Engineers familiar with steel and concrete, etc.. are requesting "hard numbers" to support the case. All the Wood books I can search through have charts for wood properties, but the specific question I have been asked is "how much impact and wear damage does it provide?"
I am seeking an answer for the pipeline engineers. Despite their logical trust in the solution, Common sense will not cut it. Engineers need numbers!
If you wrap a pipe with Kiln Dried 2x4's, how much "mechanical protection" does it provide from a wood scientist's perspective? Impact/Compression Strength, etc..
Thanks in advance!
Thanks in advance!
