tmills
- Nov 23, 2005
- 8
Do any of you have any details or experience with using galv. metal straps for X bracing in wood stud shear walls. This would be for internal shear walls on multi-story wood framed buildings. I have seen them used on other projects by other firms but we can't get comfortable with the numbers using nailed strapping. Are there products out there designed for this application? We usually will default to a plywood shear panel with Simpson floor to floor ties.
Are there any good references on this subject?
