StrEng007
- Aug 22, 2014
- 537
I have arrived at some confusion regarding the role that sheathing and blocking play when it comes to bracing the studs used in wood wall framing.
Below is a list of statements that provide my current understanding of how we apply these materials. Please don't get upset if something I have written is wrong, I'm trying to get things straight and provide a reference for anyone else who searches this topic in the future.
If anyone has codified references, whether from a building code or design standard, that supports my answer or whatever the correct answer is, please let us know below.
If any statement for #1 through #7 is incorrect, please let us know.
Sheathing provided to brace wood studs for axial loading (not flexure/out-of-plane loading)
1) Sheathing must be applied on ONE SIDE only. This will only brace the stud against axial buckling about the stud's weak axis.
2) Gypsum board sheathing is unreliable due to vulnerability to damage. Therefore gypsum board sheathing doesn't provide any axial bracing.
3) If the sheathing also acts as the sheathing panel for a shear wall, you cannot use this sheathing to brace the stud for any axial buckling.
Sheathing provided to brace the wood stud length for flexure/ out-of-plane loading
4) Sheathing must be applied on BOTH SIDES since wind occurs in two directions.
5) Gypsum board sheathing is unreliable due to vulnerability to damage. Therefore gypsum board sheathing doesn't provide flexural bracing.
6) If the sheathing also acts as the sheathing panel for a shear wall, you cannot use this sheathing to brace the stud for flexure.
Blocking provided to brace wood studs for flexural loading, axial loading, and combined bending and axial.
7) Full depth blocking provided at mid-height of stud, reduces the weak axis slenderness ratio by 1/2 AND reduces the flexural unbraced length by 1/2.
8) The blocking from statement #7 must be continuous across the entire wall segment.
Two follow up questions:
Q1: If there is no sheathing at all, and only blocking is provided, how do you handle the build up of brace forces that exist in the blocking?
Q2: If there is sheathing applied, and the sheathing is attached to the blocking, can you disregard the build up of shear forces and accept they are simply handled by the sheathing through vertical diaphragm action? Or do you need a discrete method to resolving that load (similar to the design of cold formed steel stud)?
