n3jc
- Nov 7, 2016
- 189
yellow - openings
blue - timber posts, diagonals for bracing in a wall
There is a plywood sheating on a roof, diagonals between posts and openings for bracing in X and Y directions.
My question: For bracing in X direction I made 2 trusses (0,70 m wide) on each side of large opening. One of them is rotated for 10 degrees.
What do you think about this solution and what would you do? I cant use steel moment frame or something other than timber.
Thank you.
Thank you.
