wooden garage - bracing
n3jc
189
yellow - openings
blue - timber posts, diagonals for bracing in a wall
There is a plywood sheating on a roof, diagonals between posts and openings for bracing in X and Y directions.
My question: For bracing in X direction I made 2 trusses (0,70 m wide) on each side of large opening. One of them is rotated for 10 degrees.
What do you think about this solution and what would you do? I cant use steel moment frame or something other than timber.
Thank you.
is this an open structure? If you are making an enclosed, framed garage, plywood is what is typically used for shearwalls and roof diaphragm to take down lateral loads - this looks like an overkill - and you will have issues attaching siding over the diagonals. You should probably just hire an engineer, this would not be an expensive job, and it would be done right.
