Workbench 19: Submodelling (?) error
IJR
774
Friends
I first prestressed the model using INISTATE. Then duplicated it. In the duplicate, I loaded
the second model with displacement loading only. I linked the second model to the first
so that I can retrieve the results from prestress loading. The linking was successful because
the second model inherited all the geometry and the meshing correctly.
The screenshot attached is for the second model. I am unable to retrieve the results from the
prestress analysis.
How can I deal with the question mark? The details are at the bottom of the screenshot.
Thank you in advance
ijr
 https://files.engineering.com/getfile.aspx?folder=e88baf85-6f67-4565-995e-65e5e4452506&file=submodelling2.jpg
