Workbench solution combination
L_K
267
Is there a way in Workbench to input many solution
combination coefficients efficiently?
For example if one solution combination consists of 12 load cases
and there are >10 solution combinations which have to be calculated.
Hi
If all load cases are linear, just Right Mouse on Model > Insert > Solution Combination. Then Add to set your coefficients for each basic case. You can then copy the Solution Combination and go into it to edit coefficients as required.
David
Am I correct it is not possible to input all the coefficients with one copypaste but they have to be copypasted one at time?
I have a list of coefficients (altogether >100 values) for different combinations which I got from other software.
Hi
The other way round this would be to set up all the combined load cases and use Parameters to input the factored loads to each. Parameters can be read in from your external data.
David
Load case operation could be computed with APDL. It may be worth your while to look into it if you've a lot to deal with.
Kind regards,
Jason
