Workstation PC Build for Large Deformation Finite Element Analysis (Explicit)
lyonisk888
8
Hi Everyone,
I am currently thinking of building a new workstation PC for ABAQUS Finite Element Analysis, I am running ABAQUS CAE 6.12 on my computer with these specifications:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor 6MB cache
GPU: Nvidia GTX 970 4GB GDDR5
SSD: Samsung 850 250GB 2x (Raid 0)
HD: Seagate Barracuda 1TB
RAM: Corsair Vengeance 1600MHz DDR3 CL9 16GB
The simulation is taking days and I am wondering if it is it worth building a workstation PC with 32GB of DDR4 memory and an Intel Core i7-5820K 6 core processor with 15MB cache to reduce computational time? I am doing a Large Deformation Finite Element Analysis (Explicit) using the Coupled Eulerian Langragian(CEL) method. Feedback from others who have done FE analysis (Explicit) using abaqus on workstations vs servers or desktops would be great!
Thanks For taking your time to read this!
Unfortunately, you may not have much choice; CEL is a computationally expensive analysis. Running a 'simple' CEL analysis on tens of CPUs on a Linux cluster can easily take hours. That said, all is not lost. You can try to coarsen the Eulerian mesh as a first step; that will give you the biggest bang. Another option is to try *Eulerian Mesh Motion (see the manual for details).
Are you new to this forum? If so, please read these FAQs:
If its a one and done job, you could try contacting a company that provides "cluster for hire" services (and supports Abaqus) for a quote? Here is one I found on google:
If you are in academia there are often state-funded HPC providers that will support your research free of charge (i.e. give you access to a cluster).
Otherwise I would exploit every possible method of reducing your analysis time and stable time increment before committing to the investment.
In addition to Dave's suggestions, you might want to look into increasing the density of the materials because mass scaling won't work in CEL (as long as the physics allows it). But, to be sure, you should request output to ensure the averaged density (DENSITYAVG) makes sense. Also, keep ODB frames and output to a minimum (e.g., LE, PEEQAVG, U, etc. may be avoided).
Dave & IceBreaker Thank You for your advice, it has taken two days for the analysis to run for just 1 second of time step -.-
Coarsening the Eulerian mesh is not really an option as I will have to do a mesh convergence analysis. I don't have access to HPC in my University so I think I should probably just let my computer run constantly and hope for the best as it seems like there is not that much I can do and Hiring a cluster seems a little out of my personal budget for my thesis.
You can do the mesh convergence analyses once you have ensured the analysis is doing what it is supposed to be doing. Your first analysis need not be one with a very fine mesh.
By the way, one second is a LOT of time for an explicit scheme (which is what CEL uses), particularly with the kinds of element sizes and numbers involved in CEL analyses. Half a second or less are typical times for such analyses.
In addition to previously mentioned workarounds, you might also wish to look in to BCs such as non-reflecting ones for a smaller Eulerian domain. Also, you can be clever about your mesh seeding so you have a fine mesh only in areas of high interest.
To minimise the Eulerian domain I used a quarter model and applied a symmetrical/encastre boundary condition as the primary analysis is only in one direction. I did a couple of analyses using large elements but they gave some misleading results but now that I have partitioned the eulerian element and used dense mesh in areas of high interest. I had no idea how computationally intensive CEL and finite element analysis is. Would having more CPU cores and memory significantly help or not really for when i need to run mesh convergence analyses?
Your university may have access to a state/national HPC resources, even if there isn't one at your university. I'd be very surprised if there is no way for you to gain access to a cluster.
I found out that the only supercomputer/HPC centre in my area is called Pawsey here in Perth, Western Australia. The problem is I would have to submit an application which would only be assessed at the end of December by then my thesis would already be due -.-. I was told computational time would be long, no one told me days long I was naive to think that it would take a couple of hours to simulate a simple anchor penetrating the soil I guess...
Unfortunately, some of the advanced analyses like CEL or SPH etc. aren't truly ready for widespread usage. They are simply too expensive. Can you not, somehow, perform a Lagrangian analysis?
The large deformation compromises the mesh structure and gives some really misleading results. I think I might just build a workstation of anyways because I used up 80GB just for a step time of 1 second and I have to do at least 5 seconds....
By the way, mesh convergence for CEL also includes Eulerian domain convergence (which will further increase the computational cost), wherein you increase the size of the Eulerian domain to check what the reflections from the boundaries are doing to your solution.
I'd set the job running last thing on a Friday to run over the weekend, and just hope that when you arrive back on Monday morning you don't see a message on the screen that says "Previous job name exists, do you wish to override (Y?N)...". It happens.
Yea i'm not looking forward to this computational time its going to kill me!
One thing I learned by watching an FE 'guru' is that you should play a LOT with a coarse mesh model so you can make lots of mistakes and fix them quickly, and finalize on a set-up. Only then should you make the model 'realistic' and do your actual analyses. Otherwise, along corus' line of thought, you end up spending/wasting hours/days on inaccurate/imprecise/junk models. This is even more so true for expensive analyses such as CEL.
By the way, check out the Director's Allocation Scheme at Pawsey. It may not be much but it may very well be an order of magnitude or two better than your set-up.
They use some amazing haswell Xeon processors that are several magnitudes higher than I would ever afford... But you do have a good point in terms of using coarse mesh and making heaps of mistakes first before doing your final analysis!
Do you need to model the soil? what are you trying to measure?
If your computational time is going to limit the amount of useful work that you can do, you should consider simplifying your analysis. If you are only interested in the behavior of the anchor, for example, could you make some sort of simplifying assumptions with regards to the loading and run a static analysis instead?
Dave
Hi Dave! Thanks for your reply! Unfortunately I am analysing the soil behaviour as the anchor penetrates, settles and eventually pull out. I am trying to measure embedment depth and pullout capacity. Is there any suggestions to ease this situation?
While I do not know, odds are there are some relevant examples in the documentation. I know for sure that pore-pressure elements are typically used in computational geomechanics.
