HH Choi
Marine/Ocean
- Nov 30, 2022
- 4
Hi there,
I would like to ask advice about applying torquing where hydraulic tensioning has been completed.
One of reports describes that some nuts on flange joint are rotating (I mean tighten) by torque wrench (hydraulic or manual) when apply torque value per ASME PCC-1, even if it has been completed by hydraulic tensioning. Please note that it was just different method and the interval was quite short, in few days. However observed nut engaging. The joing was supposed to be 50% hydraulic tensioned, and processed following vendor (SPX SRT3) procedure. I would like to mention that readiness, tensioning value and work sequence were conducted in a correct manner.
I recognize various factors are affecting on tensioning and torquing, but the question is could nut rotate even if it has been tensioned idealy? For example,, say 100 is the ideal level to hydraulic tensioned, and it is 100% achieved. On this condition, what will happen if try to rotate nut by hydraulic torque wrench? I think nut should not move if torqued idealy in 100 level, but in reality it moves because of +/-30% tolerance to achieve target. How do you think?
Many thanks in advance.
