TEDstruc
- Dec 6, 2017
- 43
Would you consider the channel at midspan of the attached angle beam to laterally brace the angle?
My initial thought was "No", because the vertical leg of the angle is in compression and the channel is welded to the horizontal tension leg of the angle. On the other hand, I do think channel prevents torsional warping of the angle.
I've already checked the frame assuming no lateral bracing at midspan of the angle. But was curious what others thought.
