WPS Approval
deepu78
51
What Qualification/certification required for WPS review and approval for a ASME HX fabrication?
Is this specified in ASME IX?
If the WPS not checked/approved by a qualified/certified Welding expert correctly ,how can the risk of weld failure avoided?
DV
Ummmm...
Do you understand that anyone can decide if the welding is good?
Without any training?
This is why I (a metallurgical engineer) hire a CWI to observe the welding and then hire accredited labs to do the testing.
So that I can sign off knowing that everything was correct.
And I give everyone's credentials.
I don't have confidence with the laboratories, I lost a client due to an error in the bending test. Now I witness all the tests in the laboratory.
I also lost a client due to the mistake of a certified paint inspector.
