Trestala
- Feb 15, 2015
- 175
I am trying to evaluate some nozzles with applied external loads (d/D = 0.47 and 0.55) using WRC 497. These are nozzles with reinforcing pads.
When commercial softwares use WRC 107/537, they evaluate stresses on both nozzle edge and pad edge using corroded thickness. However, WRC 107/537 considers the nozzle as rigid.
WRC 497 considers the thickness of the nozzle in its evaluation. I am evaluating the stresses at the nozzle edge using shell thickness with pad less corrosion allowance, and nozzle thickness less corrosion allowance. However, for the pad edge, I need a nozzle thickness value to get the stress values at this location.
Part 1, Sec. 15 of WRC 497 mentioned the use of pads and consideration of pad thickness, but no mention of evaluation at pad edge.
Also, on Part 8 of WRC 368, they have cited examples with reinforcing pad and did not mention any evaluation of stresses at pad edge.
Question 1: Do I need to evaluate stresses at pad edge for WRC 497, like how commercial softwares do for WRC 107/537?
Question 2: If so, how would I consider nozzle thickness for t/T value.
Design Code: ASME VIII, Div.1
Acceptance Criteria: ASME VIII, Div. 2, Part 5 as per U-2(g)
