USAeng
- Jun 6, 2010
- 419
example:
machinist handbook shows max width across flats of nut... pick a 13/16 (.8125) nut and you have wrench opening of .818-.826. So I would call out wrench flats to be about .810 which is approx 13/16 which would have +-.005 on our part so wrench would fit ok... that's what I would do right now with my interpretation of the book...
is this a good way to do it? say if I pick a 5/32 wrench flat... then there is less between the max width of nut and minimum wrench opening --> so the handbook shows 5/32 nut to have a corresponding .158-.163 wrench opening. I would pick .151 +-.005 for wrench flats.... but this is much greater difference in comparison.... so maybe in this case one should pick .156 +.000-.005 for the flats?
thoughts? any general rules of thumb or maybe just a chart? if there is no chart or general rules- I was just going to make my own for every standard size. Thank you
