jraef
- May 29, 2002
- 11,360
For those familiar with Wound Rotor Induction Motors, I have an odd problem. The end user my DC injection brake has "rewound" his WRIM to be a squirrel cage induction motor. At this point I do not know what he means by "rewound", and I suspect that all he has had done is internally shorted the rotor windings. Typically this results in extremely high starting currents, but in this case he has a solid state soft starter, so that problem is masked. The new problem is that he has now installed a current-controlled DC injection brake on the stator and it continually blows fuses as soon as it is energized. My theory is that by shorting the WRIM rotor, he has created a SCIM with little rotor resistance (thus the high starting currents) which works in reverse as far as the DC injection brake is concerned because the rotor cannot create a strong counter rotating field to apply impedance to the stator windings. The brake current thus rises too fast for the SCRs to control it, and the fuses blow. Any comments?
"Venditori de oleum-vipera non vigere excordis populi"
