Wrinkling of Membrane Patran
bagnaedo
Aerospace
Hi, I'm Edoardo and I'm attending the last year of Space Engineering. For the Space Structures Laboratory, I'm simulating the modeling of membranes and the wrinkling phenomenon (solar sails). However, I'm having a lot of problems with patran, most of them are related to convergence problems.
I know that there are a lot of pdf talking about it but I need some advice.
One of the papers that I'm following is about a membrane under a shear load (Pellegrino). In patran, I created the points, the curves, the surface , the material (isotropic kapton), the property (2D shell) and then I applied as boundary condition an encastre at the bottom edge, a displacement of 0.05mm along the y axis at the upper edge (in order to pre-tensioning the membrane) and, for the next subcase a displacement of 3mm along x axis in the upper edge.
For the analysis, I used the sol400 with a linear static step for the first subcase and a buckling step for the second subcase. However, I've different fatal error.
Someone can help me? Thank you very much!
