write array parameters into txt file
ph47reey
DE
hello fellow ansys-users,
let's say I have succesfully created an array with name "evalx". This array has a dimension of 39 rows by 12 columns. The rows contain the nodal x-displacement of selected nodes and the columns contain the corresponding eigemodes.
And now I want to print the array with 39 rows and 12 columns as a .txt file on my harddrive. I have copid the command line as follow:
*CFOPEN,outputdateiXmode1a,txt,,C:\User\Documents\Eigenmodes\evalx*VWRITE,evalX(1,1)
(F10.5)
*CFCLOS
As far as I have understood it, it loops automatically, writing values from each row and each column.
However it does not function and I got a "COMMAND LINE CLOSED" notification on the outpot window.
Could somebody please help me? I thank you very much.
you should tru *mwrite command.
*MWRITE, evalX, C:\User\Documents\Eigenmodes\evalx\outputdateiXmode1a, txt, , JIK, 12,
(12F10.5)
or you will have to add
*VWRITE,evalX(1,1),evalX(1,2), evalX(1,3),evalX(1,4),evalX(1,5), evalX(1,6),evalX(1,7),evalX(1,8), evalX(1,9),evalX(1,10),evalX(1,11), evalX(1,12),
and it can only be used via batch mode or via /input command
