Writing Marcos 2
staryash
Bioengineer
Jun 15, 2006
8
I have marco recording as attached, and I would like to improve the style, so that I can write the macros without running one and editing them.
Please let me know which part is gonna be dynamic?
I do not understand your question, it is not a dynamic simulation.
I do not know how to break the macro into separate lines without causing any problems.
Staryash,
You can run a macro using execfile('marcofile.py') as well as "File>Run script" menu. I though you wanna make the script more changeable (dynamic). In the case, you could use x=getInput('x=','default value for x').
HI Msha
I created this macro by recording the procedure in ABAQUS, and when I want to use it I have to edit the filenames.
And, all the commands are in one straight line.
I want to know, where the appropriate breaks are, or a suitable (free) editor of the macro. So for example..
123 4567 890 1234567890 ...
can be written as
123 4567
890
1234567890...
as appropriate for ABAQUS.
I can run the script, by using macro manager.
I use notepad++ as my py editor, and it has all the entries on separate lines already. I forget which, either notepad or wordpad, but one of them has a problem reading carriage returns and line breaks for me, replacing them with little rectangles. Try Notepad++. It rocks.
Staryash,
Abaqus 6.7 and later has a Python editor and debugger as well. you can find it in "File>ABAQUS PDE" menu.
Notepad++ is a free editor.
I myself use PyScripter. It is free and very powerful for professional scripting.
