wrong placement of dimension in drawing after update links of part
psychanalyst
Computer
Jan 29, 2014
3
hi,
I am trying to make a macro to update links between CATDrawing and CATPart. After execution of the macro, there are losses colored red annotations.
Here is my code:
Sub CATMain()
partFile = CATIA.ActiveDocument.FullName
Set partDoc = CATIA.Documents.Read(partFile)
Set myPart = partDoc.Part
drwFile = Replace(partFile, "Part", "Drawing")
Set drwDoc = CATIA.Documents.Open(drwFile)
Set mySheet = CATIA.ActiveDocument.Sheets.Item("Sheet.1")
For i = 1 To mySheet.Views.Count
Set myView = mySheet.Views.Item(i)
Set vLinks = myView.GenerativeLinks
vLinks.RemoveAllLinks
If InStr(myView.Name, "Main") < 1 Then
If InStr(myView.Name, "Background" ) < 1 Then
vLinks.AddLink myPart
End If
End If
Next
mySheet.ForceUpdate
'CATIA.ActiveDocument.Save
End Sub
I know that catia will keep dimensions linked when you use the proper way... I am not sure it will keep links when replaced with a script.
Eric N.
here is my drawing before running the code
viewer.php
this is how it looks as a result
viewer.php
When creating dimensions to holes, do not select the center line. Tag the hole itself when dimensioning.
If you have not already done this, try it. Then run the code and see if they fail.
