SteelPE
- Mar 9, 2006
- 2,759
I have a project that is literally days away from being completed. The architect client had specd out a plywood sheathing with a foam backing to be placed on the outside of the wood framing. We identified this early on as being an issue with regards to lateral force resistance. We called the proposed manufacturer to find out that there was no published shear values for their proposed wall system. We then offered to the client the ability to sheath the inside of the building (which has it's own issues related to inspections of blocking and such). We both agreed that this wasn't a viable option.
Then, the other day, this video pops up on my YouTube feed (skip to 11:45):
I don't necessarily like these systems as they just don't pass the smell test, but according to their website, they do have published shear wall data which can be found here:
ICC appears to also have published data:
Now, I understand that the shear values are not great when compared to standard WSP panels applied directly to the face of the stud. Has anyone used these products before?
