While watching the latest Nova Program concerning the whys and wherefore of the WTC collapse an interesting point came from one of the investigators/narrator. It concerns the failure mode of the bolts holding the floor joists to the beams. The description was going along very well as he explained the fire with resultant sagging of the floor joist. When he was describing the connection failure that caused the progressive collapse he noted the bolts were supposed to fail in shear. He then said that due to the sagging joist the bolts failed in tension. If I heard him right he then said this was the weakest direction. I think the weakest direction was a slip.
Can anyone explain how the bolt at the joist to beam connection could ever be in tension? Even with the joist on the floor below the clip would also be bending and the bolt would still be in shear.
Here is an interesting site on the WTC.
