Wye motor in delta power system
peasant
6
I've supplied several motors on a project (in USA) that utilizes a delta power system. Most/all of my low hp motors appear to be wye wound. The client believes all motors must be delta wound for use in a delta power system.
Their reasoning is that when a wye only wound motor is connected to a delta power source, it carries only 67% voltage across the winding, providing less horsepower. Under full load operation, the motor is more likely to fail.
Can a wye wound motor can be used in a delta power supply? Why or why not? Thank you.
As long as the rated phase-phase voltage is correct there is no difference between how a wye wound motor and a delta wound motor would respond to the power system.
Thank you. A follow-up question about grounding:
I'm told my client will accept wye wound motors where the motor winding is not grounded. Isn't this inherent to wye wound motors? Are there problems using a wye wound motor with grounded winding in a delta power system?
A grounded winding would be an odd duck; that's pretty much never done.
You are confusing POWER SYSTEM configurations with MOTOR WINDING configurations. Apples and oranges.
OK, maybe lemons and oranges... same genus, different species.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
