I have a project that requires replacing an AC drive system, which is powered by a 3MVA 11kv//690V wye-wye transformer that is not grounded. The secondary has the neutral point available but it is not connected. I am not comfortable in leaving the system floating and the equipment manufacturer does not recommend this also. I wish to ground the secondary of this transformer using HRG but am concerned about triplen harmonics and any other issues that could arise by doing this with this type of transformer. Also will my ground fault detection circuit work with this arrangement?
Another alternative I am considering is to use a zig-zag earthing transformer with HRG to create my own neutral point, and leave the main transformer neutral unconnected. is this a better option?
Replacing the main transformer with a Dyn11 style is out of the question...
thanks for any thoughts on this issue.....
