To all,
I am curious how most engineers handle the analysis of 'X' bracing with regard to lateral support out of plane.
I noticed the "Tension Only" thread as well, so I thought it might be a good time to start a discussion on vertical bracing. I typically use RAMAdvanse, but have used other 3D analysis such as STADD and RISA. When building a model I typically do NOT add a node at the intersection of the 'X', otherwise I would have to manually input the effective length of the brace, as I do not consider the members braced out of plan. Now of course Tension Only members will avoid this all together; however, your reactions will be higher having only half the members doing the work (half being relative to a symmetrical structure).
I have also read articles, where a certain amount of out of plane lateral support can be provided to the compression member by the tension member, based on the connection and the continuity of the bracing.
Again, I was wondering how others view this and their approach to design.
