i am trying to figure out how the x/r ratio is determined for power transformers, given only nameplate %Z information. i use SKM software currently, and based on some backward calculations using their default x and r values, have determined that the impedance angle used is approximately 80 degrees. this makes sense to me, in that the impedance will be mostly reactive (close to 90 degrees) for tranformer windings. is the 80 degrees an assumed value? if so, what is the assumption based on? with an impedance value from the nameplate, and an assumed angle, the x/r ratio is easy enough to determine. any help in this matter would be appreciated!!
