xline command 1
rwbaker
Computer
How can i create a vertical and horz xline
at the same time
i have tryed
^C^C_xline H;^C^C_xline v
but with no results
Try ^C^C_xline H @0,0;^C^C_xline v @0,0
thanks
works great
But anyway to get it to work off of a current point ?
What point do you want?
@0,0 is "nowhere" from the last point.
If you did ^C^C_xline H pause;^C^C_xline v @0,0 it would prompt you for a point then use the same point.
^C^C_xline H pause;^C^C_xline V @0,0
When i use this line all i get is a horz line
^C^C_xline H @0,0;^C^C_xline V @0,0
when i use this it draws a horz at the
last point and prompts me for a vert point
I must be doing something wrong ????
Try this using a space to repeat
the last command. Works at the
command line, but you can give it
a tryon a macro.
^C^C_xline H pause; V @0,0;
Hi rwbaker,
I have annother approach: Insert a block, and explode it...
Edit a "crossline.dwg"
-> put it in Your folder
->make a butten: ^C^C_-insert;"Your Folder/crossline.dwg";\;;;_xplode;l;;;
-> ready
Lothar
Hi all,
^C^C_xline;h;\;^C^_xline;v;@0,0;;
this worked to me.
Regards.
thanks
naujoke
that did exactly what i needed
Hey is ther anyway to work off of cursor location
like on the offset command
our current cadsystem works off of which
line is nearest to the cursor and just offsets a
construction line at whatever dim you tell it
