Hi
I am using NX 8. I often have situations where I have to get XYZ coordinate points for hundreds of point locations on a model and transfer those points to an excel spread sheet. up until now I have done it manually using "information, point" for each one and then I enter it manually into Excel. the points I am taking are actual UG points i have entered in on a special layer when i was creating features.... like it is the point on a curved surface where a hole originates. I know I can do all the points at once and get a large listing that I can sort in excel but that does not allow me to determine how to put the points in an order we desire as decided by the customer.
Ideally I would like to select the point in UG and see the XYZ points appear in my spreadsheet in 3 columns right at the time I selected it and maybe without extra commands like copy and past etc.
I appreciate your ideas.
thank you
thank you
