A problem which we are presently facing is that orthophthalic polyster resin purchased from two different locations are having two different colours .One is yellowish whereas the other tends towards green . Due to the big difference in the colour the products made from these two locations though identical in process are looking tone wise different . The supplier is at a loss as to why such a difference exists between their polyester an that from another supplier .
Can someone suggest the possible components to check which may be responsible for the resin colour moving towards green .
The resin comes already mixed with stirene and it is in a ratio of around 65 ester to 35 styrene.
Thanks in advance ,
Nik Smith
Thanks in advance ,
Nik Smith
