jsanders2008
- Jun 19, 2008
- 6
I am trying to calculate the maximum deflection of the wall of a walk-in air-handling unit. The wall is comprised of two steel sheets with foam insulation inbetween, and can be considered a rectangular beam, fixed at two ends, with a uniform load.
As I understand it, the equation for calculating deflection in a beam fixed on two ends with a uniform load is as follows:
d = 5 * F * L^3 / 384 * E * I,
where d is the deflection of the beam,
F is the force of the load,
L is the length of the beam,
E is the modulus of elasticity (Young's modulus) of the material, and
I is the second moment of area.
In this case, I believe the second moment of area would be as follows:
I = b * h^3 / 12,
where b is the width/depth of the beam, and
h is the thickness of the beam.
(The dimensions of the beam are L x b x h. See attached file for an illustration.)
Assuming the previous information is correct, my problem is that I don't know what to use for the modulus of elasticity (E), because there are three layers in the beam, which are made of two different materials.
I'm hoping that there is a way to calculate an "equivalent modulus of elasticity" based on the materials and thicknesses of each layer in the beam. Does anyone know if this is possible, and if so, how to do it?
I appreciate all help. Thanks.
I = b * h^3 / 12,
