SprinklerDesigner2
- Nov 30, 2006
- 1,264
Just started exploring and the more I read the more questions I have.
To be specific I am looking at Ceilume's approved drop-out ceiling panels can be installed beneath fire sprinklers.
What is really disconcerting is there's some on the market that are marketed to be installed below ceilings but I couldn't find the UL or FM Mark on anything.
I got a feeling I could run into a real problem in a Light Hazard restaurant seating area where quick response sprinklers are required but the ceilings delay the response times? Could I end up with something where I could only use these tiles in Ordinary Hazard areas and if I do I would not be able to use the area reduction in areas that have a ceiling not exceeding 20'?
To be clear I am using the term "ceiling" to refer to the actual roof above the suspended ceiling not the drop in ceiling.
Also, unless I am reading it wrong which I sometimes do, the specific head has to be listed for use above these drop out ceilings?
I would appreciate any actual experience or input you may have.
