SJBatTCE
- Oct 8, 2001
- 41
When you have a panel feed directly from an unprotected source (i.e., large transformer secondary) you will generally have a high arc-flash hazard at the incoming lugs of the panel. On an installation such as an I-line (or similar construction), will the selection of the main breaker settings reduce the HRC for the panel or does the entire panel require labeling for the hazard present on the main breaker's source terminals?
