Z88 Aurora - model problem
GregLocock
Automotive
Orbiting a small yellow star
I include a very simple problem, a flat plate simply supported on 3 edges with uniform loading (OK I know that corner and midpoints should get different loads, nonetheless...)
However the thing doesn't solve. I'm sure the reason is blindingly obvious but am currently stumped. FWIW all the example files run that I've tried, so it isn't an installation or permissions problem.
First error is in z88sets.txt which somehow has the old set names
Code:
6
#ELEMENTS ELEMENTGEO 54 9 "Geometry55"
         1          2          3          4          5          6          7          8          9
#ELEMENTS MATERIAL 57 9 "Engineering steel"
         1          2          3          4          5          6          7          8          9
#NODES CONSTRAINT 68 17 "ConstraintsZ"
         2          3          4          5          6          7          8         15         22         29
        36         44         45         46         47         48         49
#NODES CONSTRAINT 69 1 "CONstraintxyz"
         1
#NODES CONSTRAINT 70 1 "xonstXZ"
         43
#NODES CONSTRAINT 77 30 "loading100"
         9         10         11         12         13         14         16         17         18         19
        20         21         23         24         25         26         27         28         30         31
        32         33         34         35         37         38         39         40         41         42
