Hi all,
So I was wondering, how do we assure the quality of a special process when no on is looking? It's like the question, if a tree falls in the forest does it still make a sound if there is no one there to listen?
We've been having an on-going discussion concerning welding on a concrete thread. Out of respect to the rock-hounds, we are moving this discussion over here. If you feel like you are picking this up in midstream, don't worry, you are. But like all philosophy, it doesn't matter where you jump in or really what your level of comment is. Kirkegaard or Alfred E. Neuman, it won't matter.
So we kick it off by saying should engineers make do or get by because of job site conditions or locations.
We had a question concerning welding rebar. I maintained there are all sorts of "weldable" rebar if proper practices are followed. Others joined in that rebar wasn't weldable because you can't control the process.
Phewy.
To CWIC: Just the facts, Man.
1) Regardless of whether or not a jurisdiction implements UBC or IBC, the owner has the right to impose inspection. The design codes, like all others, are minimum standards. Likewise, buliding officials can impose restrictions on substandard practices. If we choose to blink so we can support the tax-cuts that cut our regulatory budgets that is a moral question. I think we need to do some soul searching here. Ah, philosophy.
2)AWS makes it the responsibility of the inspector to judge the ability of a welder. No one else in the design,build, assure team has that responsibility. If the inspector has any reason to doubt the capability of the welder, he can require retesting of that welder. If they're a bad welder, they will probably fail the test. Again, do we blink so we can milk the job for a few more weeks.
I have shut down shoddy inspection agencies in my time, because they were not performing RT in conformance to Code and wouldn't get into to line. They blustered just like an old welding foreman and tried to stone-wall me. They don't do much work in our area anymore. It isn't just welding that is out of control.
I know I haven't addressed all of the facts, but I have patience. As the I Ching says, "Perseverence Furthers".
Koz
Phewy.
Koz
