M MOTAAL
- Aug 22, 2018
- 22
I have a model in which i have defined fastener connector section to simulate self drilling screws in a cold formed sheet. I have chosen a connector sec. of type Cartesian and Align for the connection.The reason why I selected these types of connection; is that I needed to provide a failure criteria for the software to stop the analysis when reaching the shear capacity of the screw. And as far as I know, this criteria can be defined by defining lower and upper forces bound during defining the section within a predefined orientation in ABAQUS.
Is this a right choice(Cartesian and Align) or there is another better selection?. That was my first question and the second is about the connector output, how can I demonstrate the internal forces within the connector element? I have defined a field output in which I requested for connector elements results like CTF, CEF and CU but when I try it all the results are zeroes. So I think that I have missed something in the whole definitions procedure.
Thank you in advance.
