I am conducting the post-buckling analysis of a cold-formed steel C section column that is connected to a small length U section at the top and bottom.
The displacement-controlled loading has been applied at the top through a rigid plate(discrete rigid).
I have applied the fixed boundary condition at the mid-reference point of the rigid plate at the top and bottom.
While running the analysis I am getting zero pivot warning and the analysis is being aborted after a few time steps.
Could you please advise, how I can improve the boundary conditions and what are the other alternatives that I can explore to avoid this zero-pivot warning?
The image of the model is attached as a ready reference.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1659888562/tips/Zero_pivot_warning_ziard0.docx[/url]
Many thanks!
Many thanks!
