The situation: Neighboring utility uses the the same voltage wye grounded system as we do, but is shifted from us by 60 degrees. In order to allow a closed transition transfer, our neighbor is proposing to use a delta/zig-zag phase shifting transformer. I know zig-zags are used for grounding, but fail to see how ground currents would pass to the delta side without getting trapped in the delta connection. Can anyone explain?
